Ir para o conteúdo principal
Acer Chromebook CB5-312T-K 8Z9 Battery Replacement
O que você precisa
  1. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: passo 1, imagem 1 %32 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: passo 1, imagem 2 %32
    • First begin by flipping the laptop on its back and having the back cover face you directly.
    • Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
  2. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: passo 2, imagem 1 %32
    • Using a plastic spudger, open the back cover and remove it from the laptop.
  3. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Battery: passo 3, imagem 1 %32 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Battery: passo 3, imagem 2 %32 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement, Battery: passo 3, imagem 3 %32
    • look for the battery in the bottom half of the computer
    • Once you have found the battery, look for the screws that secure the battery, in the upper left and right corners.
  4. Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: passo 4, imagem 1 %32 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: passo 4, imagem 2 %32 Acer Chromebook CB5-312T-K 8Z9 Battery Replacement: passo 4, imagem 3 %32
    • Begin by unscrewing the two Phillips head screws that hold down the battery using a J1 sized screwdriver.
    • Finally remove the battery from the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 1,474
