Introdução
This is a guide to replace a faulty motherboard in an Acer Chromebook CB3-431-C5EX laptop. You will need a Phillips #0 screwdriver, iFixit opening tool, Tweezers, and a Heat gun. Be cautious when removing the motherboard because of having to handle wires.
O que você precisa
Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
Remove the bottom panel and set it aside.
Remove the two 4mm Phillips #0 screws on either side of the battery pack that are securing it in place.
Remove the 4.7 mm screw from the Wi-Fi card using a Phillips #0 screwdriver.
Remove the Wi-Fi card from the laptop.
