Ir para o conteúdo principal
Acer Chromebook CB3-431-C5EX Battery Replacement
O que você precisa
  1. Acer Chromebook CB3-431-C5EX Battery Replacement, Bottom Panel: passo 1, imagem 1 %32
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Battery Replacement: passo 2, imagem 1 %32
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Battery Replacement: passo 3, imagem 1 %32 Acer Chromebook CB3-431-C5EX Battery Replacement: passo 3, imagem 2 %32
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Battery Replacement, Battery: passo 4, imagem 1 %32
    • Remove the two 4mm Phillips #0 screws on either side of the battery pack that are securing it in place.
  5. Acer Chromebook CB3-431-C5EX Battery Replacement: passo 5, imagem 1 %32 Acer Chromebook CB3-431-C5EX Battery Replacement: passo 5, imagem 2 %32
    • Disconnect the taped white 8-pin cable on the bottom right of the battery pack.
    • Use thumbnail to pull on the small protruding tabs on either side of the connector.
  6. Acer Chromebook CB3-431-C5EX Battery Replacement: passo 6, imagem 1 %32
    • Carefully lift the entire battery pack out of the laptop.
Conclusão
7 outras pessoas executaram este guia.
Elsa Bassett
Membro desde: 04/18/17
414 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S17-G3, Banghart Spring 2017 Membro de Cal Poly, Team S17-G3, Banghart Spring 2017
CPSU-BANGHART-S17S17G3
Membros da 5
Autoria de 10 guias
2 comentários
A heat gun is listed as a need tool, but the instructions do not mention using it.
Medium strength (blue) threadlocker compound should be used during reassembly.
Stephen Gertsch - Responder
why didnt it stop giving instruction I think I got the wrong battery pak no more acer for me acer 14 they dont know what batterty to send you what a joke LOL
woody wilson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 52
Duração total: 8,543
