Ir para o conteúdo principal
Acer Chromebook CB3-111-C8UB Touchpad Replacement
O que você precisa
  1. Acer Chromebook CB3-111-C8UB Touchpad Replacement, Back Panel Removal: passo 1, imagem 1 %32 Acer Chromebook CB3-111-C8UB Touchpad Replacement, Back Panel Removal: passo 1, imagem 2 %32
    • Position the laptop upside down with the hinges on the side furthest away from you.
    • Remove the eight 8mm screws with a phillips #1 screwdriver,
    • Remove the four 4.5mm screws with a phillips #1 screwdriver,
  2. Acer Chromebook CB3-111-C8UB Touchpad Replacement: passo 2, imagem 1 %32 Acer Chromebook CB3-111-C8UB Touchpad Replacement: passo 2, imagem 2 %32 Acer Chromebook CB3-111-C8UB Touchpad Replacement: passo 2, imagem 3 %32
    • There is a wire connecting the two pieces of the laptop, from the inside, on the left, be careful not to damage it.
    • Use the plastic opening tool to pry open then remove the plastic base from the rest of the laptop. Start from the right side and work towards the left.
    • Set the plastic base beside the laptop by opening it as if you were opening a book.
  3. Acer Chromebook CB3-111-C8UB Touchpad Replacement: passo 3, imagem 1 %32 Acer Chromebook CB3-111-C8UB Touchpad Replacement: passo 3, imagem 2 %32
    • Flip up the small white ZIF connector by using a fingernail or metal spudger.
    • Pull the blue tab to remove the ribbon cable.
    • The ribbon cable is adhered to the plastic so it will take a little bit of force to remove it.
  4. Acer Chromebook CB3-111-C8UB Touchpad Replacement, Battery: passo 4, imagem 1 %32
    • Locate and remove the two 6mm screws holding the battery in place with a Phillips #1 screwdriver.
  5. Acer Chromebook CB3-111-C8UB Touchpad Replacement: passo 5, imagem 1 %32 Acer Chromebook CB3-111-C8UB Touchpad Replacement: passo 5, imagem 2 %32 Acer Chromebook CB3-111-C8UB Touchpad Replacement: passo 5, imagem 3 %32
    • Pull the battery forward to clear the base from its clips.
    • Lift the battery up so that there is room to grab and unplug the bundled cable connector.
  6. Acer Chromebook CB3-111-C8UB Touchpad Replacement, Touchpad: passo 6, imagem 1 %32
    • Use a metal spudger to flip up the white ZIF connector that holds the ribbon cable in place.
    • Unplug the black ribbon cable from the track pad assembly.
  7. Acer Chromebook CB3-111-C8UB Touchpad Replacement: passo 7, imagem 1 %32 Acer Chromebook CB3-111-C8UB Touchpad Replacement: passo 7, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the three 2.4mm screws located across the top of the track pad assembly.
  8. Acer Chromebook CB3-111-C8UB Touchpad Replacement: passo 8, imagem 1 %32
    • Use your finger to gently pull up on the assembly and slide a metal spudger under each of the two strips of tape and peel them off of the main metal plate.
  9. Acer Chromebook CB3-111-C8UB Touchpad Replacement: passo 9, imagem 1 %32
    • Slide the track pad assembly up towards the motherboard until it can be lifted up and out.
Conclusão
Travis Vo
Membro desde: 01/27/17
426 Reputação
4 Guias de autoria
Equipe
Cal Poly, Team 22-7, Maness Winter 2017 Membro de Cal Poly, Team 22-7, Maness Winter 2017
CPSU-MANESS-W17S22G7
4 Membros
12 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 916
