Ir para o conteúdo principal
Acer Chromebook CB3-111-C8UB Audio Jack Replacement
O que você precisa
  1. Acer Chromebook CB3-111-C8UB Audio Jack Replacement, Back Panel Removal: passo 1, imagem 1 %32 Acer Chromebook CB3-111-C8UB Audio Jack Replacement, Back Panel Removal: passo 1, imagem 2 %32
    • Position the laptop upside down with the hinges on the side furthest away from you.
    • Remove the eight 8mm screws with a phillips #1 screwdriver,
    • Remove the four 4.5mm screws with a phillips #1 screwdriver,
  2. Acer Chromebook CB3-111-C8UB Audio Jack Replacement: passo 2, imagem 1 %32 Acer Chromebook CB3-111-C8UB Audio Jack Replacement: passo 2, imagem 2 %32 Acer Chromebook CB3-111-C8UB Audio Jack Replacement: passo 2, imagem 3 %32
    • There is a wire connecting the two pieces of the laptop, from the inside, on the left, be careful not to damage it.
    • Use the plastic opening tool to pry open then remove the plastic base from the rest of the laptop. Start from the right side and work towards the left.
    • Set the plastic base beside the laptop by opening it as if you were opening a book.
  3. Acer Chromebook CB3-111-C8UB Audio Jack Replacement: passo 3, imagem 1 %32 Acer Chromebook CB3-111-C8UB Audio Jack Replacement: passo 3, imagem 2 %32
    • Flip up the small white ZIF connector by using a fingernail or metal spudger.
    • Pull the blue tab to remove the ribbon cable.
    • The ribbon cable is adhered to the plastic so it will take a little bit of force to remove it.
  4. Acer Chromebook CB3-111-C8UB Audio Jack Replacement, Audio Jack: passo 4, imagem 1 %32 Acer Chromebook CB3-111-C8UB Audio Jack Replacement, Audio Jack: passo 4, imagem 2 %32
    • Remove the three 4.5mm screws using a phillips #1 screwdriver.
    • Now remove the chip.
Conclusão
Ryan Locatelli
Membro desde: 01/27/17
161 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 22-7, Maness Winter 2017 Membro de Cal Poly, Team 22-7, Maness Winter 2017
CPSU-MANESS-W17S22G7
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 861
