Introdução
This will guide you through the steps of how to remove the back of the laptop and access the chip that houses the audio jack and one of the USB ports. Be careful: when removing the plastic case from the back of the Chromebook, be careful not to accidentally tear the wire connecting the plastic case to the Chromebook itself.
O que você precisa
Position the laptop upside down with the hinges on the side furthest away from you.
Remove the eight 8mm screws with a phillips #1 screwdriver,
Remove the four 4.5mm screws with a phillips #1 screwdriver,
Remove the three 4.5mm screws using a phillips #1 screwdriver.
Now remove the chip.
