Ir para o conteúdo principal
Acer Chromebook CB3-111-C670 Screen Replacement
O que você precisa
  1. Acer Chromebook CB3-111-C670 Screen Replacement, Screen: passo 1, imagem 1 %32 Acer Chromebook CB3-111-C670 Screen Replacement, Screen: passo 1, imagem 2 %32
    • Unplug and power off the laptop before starting this repair.
    • Pry the white frame away from the screen with an opening tool.
    • As you move the spudger along the seam between the frame and the screen, the clips holding the frame in place will loosen.
  2. Acer Chromebook CB3-111-C670 Screen Replacement: passo 2, imagem 1 %32 Acer Chromebook CB3-111-C670 Screen Replacement: passo 2, imagem 2 %32
    • Remove the four screws within the silver brackets that are holding the screen to the back of the laptop.
  3. Acer Chromebook CB3-111-C670 Screen Replacement: passo 3, imagem 1 %32
    • Once you've removed the screws, lift the piece of tape that is covering the display connector.
    • Use a spudger to flip up the black tab on top of the connector to unlock the ZIF connector.
  4. Acer Chromebook CB3-111-C670 Screen Replacement: passo 4, imagem 1 %32
    • Pull the ribbon cable out with tweezers and remove the screen.
Conclusão
9 outras pessoas executaram este guia.
Allen Lewis
Membro desde: 01/20/16
259 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 10-5, Remmell Spring 2016 Membro de USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
Membros da 3
Autoria de 8 guias
Um comentário
Very easy. Thanks
johnqm123 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 4,973
