Ir para o conteúdo principal
Acer Chromebook CB3-111-C670 Keyboard Key Replacement
O que você precisa
  1. Acer Chromebook CB3-111-C670 Keyboard Key Replacement, Keyboard Key: passo 1, imagem 1 %32
    • Remove broken key(s) using the flat end of spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular spudger and tweezer should be used whenever possible.
    • When reinstalling the key, no spudger is needed. Just pop it into place with fingers.
  2. Acer Chromebook CB3-111-C670 Keyboard Key Replacement: passo 2, imagem 1 %32 Acer Chromebook CB3-111-C670 Keyboard Key Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Using the flat end of the spudger, very carefully lift up the corners of the cradle.
    • With the help of tweezers (needle nose works best), pull the hooks of the cradle out.
    • For re-installation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
Conclusão
4 outras pessoas executaram este guia.
Tony
Membro desde: 01/20/16
461 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 10-5, Remmell Spring 2016 Membro de USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Membros
Autoria de 8 guias
Um comentário
no help i need help putting it on with out that
Simon Kuhn - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 33
Últimos 30 dias: 80
Ao todo: 8,003
