Ir para o conteúdo principal
Acer Chromebook C740-C4PE Solid State Drive Replacement
O que você precisa
  1. Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: passo 1, imagem 1 %32 Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: passo 1, imagem 2 %32 Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: passo 1, imagem 3 %32
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the 13 screws on the back of the device using a PH0 Phillips head screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Solid State Drive Replacement: passo 2, imagem 1 %32 Acer Chromebook C740-C4PE Solid State Drive Replacement: passo 2, imagem 2 %32 Acer Chromebook C740-C4PE Solid State Drive Replacement: passo 2, imagem 3 %32
    • Remove the 3.75 mm screw with a Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Solid State Drive Replacement: passo 3, imagem 1 %32
    • Pull the Solid State Drive out of the connector.
Conclusão
Sang Huynh
Membro desde: 03/08/17
252 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 Membro de UMass Dartmouth, Team S6-G4, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G4
Membros da 3
Autoria de 12 guias
Um comentário
There are 2 types of SSD drives, m-SATA and M.2. Which does C740 use?
Guy Scree - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 748
