Ir para o conteúdo principal
Acer Chromebook C740-C4PE Heatsink Replacement
O que você precisa
  1. Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: passo 1, imagem 1 %32 Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: passo 1, imagem 2 %32 Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: passo 1, imagem 3 %32
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the thirteen 10mm screws on the back of the device using a Phillips #0 screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Heatsink Replacement: passo 2, imagem 1 %32 Acer Chromebook C740-C4PE Heatsink Replacement: passo 2, imagem 2 %32
    • Remove the four 5mm screws on the heatsink using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Heatsink Replacement: passo 3, imagem 1 %32 Acer Chromebook C740-C4PE Heatsink Replacement: passo 3, imagem 2 %32
    • Loosen the two Phillips-head screws on the fan attached to the heatsink.
  4. Acer Chromebook C740-C4PE Heatsink Replacement: passo 4, imagem 1 %32
    • Detach the two antennae cables from the WiFi card by gently pulling on them.
  5. Acer Chromebook C740-C4PE Heatsink Replacement: passo 5, imagem 1 %32
    • Gently pull the fan cable out of the motherboard.
    • Pulling too hard may break the wires or the connector itself.
  6. Acer Chromebook C740-C4PE Heatsink Replacement: passo 6, imagem 1 %32
    • Remove the cable routed through the fan.
    • Do not completely remove the cables as they are attached to the motherboard. Once they are no longer routed in the fan, leave them as they are.
  7. Acer Chromebook C740-C4PE Heatsink Replacement: passo 7, imagem 1 %32
    • Remove the heatsink from the motherboard.
    • Before changing the heatsink/fan, you must clean off the thermal paste from the CPU and apply new thermal paste.
Conclusão
Uma outra pessoa concluiu este guia.
Dylan Tocci
Membro desde: 10/17/17
237 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 Membro de UMass Dartmouth, Team S6-G4, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G4
Membros da 3
Autoria de 12 guias
Um comentário
What type of thermal paste is best used?
Tracey Arria - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 349
