Ir para o conteúdo principal
Acer Chromebook C740-C4PE Battery Replacement
O que você precisa
  1. Acer Chromebook C740-C4PE Battery Replacement, Battery: passo 1, imagem 1 %32 Acer Chromebook C740-C4PE Battery Replacement, Battery: passo 1, imagem 2 %32 Acer Chromebook C740-C4PE Battery Replacement, Battery: passo 1, imagem 3 %32
    • Make sure the laptop is turned off and unplugged before starting.
    • Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
    • Using the spudger or other prying tool, gently pry the back off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Battery Replacement: passo 2, imagem 1 %32
    • Unscrew the two 5mm battery screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Battery Replacement: passo 3, imagem 1 %32
    • Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
    • Be sure the battery is away from the clips before pulling away so as not to break the clips.
  4. Acer Chromebook C740-C4PE Battery Replacement: passo 4, imagem 1 %32 Acer Chromebook C740-C4PE Battery Replacement: passo 4, imagem 2 %32 Acer Chromebook C740-C4PE Battery Replacement: passo 4, imagem 3 %32
    • Detach the connecting cable from the motherboard by pulling away.
    • Remove the battery from the device.
Conclusão
3 outras pessoas executaram este guia.
Jacob Kahn
Membro desde: 10/17/17
273 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 Membro de UMass Dartmouth, Team S6-G4, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G4
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 478
