Ir para o conteúdo principal
Acer Chromebook C740 Trackpad Replacement
O que você precisa
  1. Acer Chromebook C740 Trackpad Replacement, Back Panel: passo 1, imagem 1 %32
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 Trackpad Replacement: passo 2, imagem 1 %32 Acer Chromebook C740 Trackpad Replacement: passo 2, imagem 2 %32
    • Place the chromebook bottom side up on a flat surface.
    • Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
  3. Acer Chromebook C740 Trackpad Replacement: passo 3, imagem 1 %32 Acer Chromebook C740 Trackpad Replacement: passo 3, imagem 2 %32 Acer Chromebook C740 Trackpad Replacement: passo 3, imagem 3 %32
    • Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
    • Applying pressure may be necessary. A click indicates the panel is ready to come off.
  4. Acer Chromebook C740 Trackpad Replacement, Battery: passo 4, imagem 1 %32 Acer Chromebook C740 Trackpad Replacement, Battery: passo 4, imagem 2 %32 Acer Chromebook C740 Trackpad Replacement, Battery: passo 4, imagem 3 %32
    • Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
    • The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience.
  5. Acer Chromebook C740 Trackpad Replacement: passo 5, imagem 1 %32 Acer Chromebook C740 Trackpad Replacement: passo 5, imagem 2 %32
    • Remove the the two 3.7 mm screws with a Phillips #0 screwdriver.
  6. Acer Chromebook C740 Trackpad Replacement: passo 6, imagem 1 %32
    • Lift the battery from the frame.
  7. Acer Chromebook C740 Trackpad Replacement, Trackpad: passo 7, imagem 1 %32 Acer Chromebook C740 Trackpad Replacement, Trackpad: passo 7, imagem 2 %32 Acer Chromebook C740 Trackpad Replacement, Trackpad: passo 7, imagem 3 %32
    • Pull the black wire out from under the the black center clips and up from the gray outer clips with a spudger.
  8. Acer Chromebook C740 Trackpad Replacement: passo 8, imagem 1 %32 Acer Chromebook C740 Trackpad Replacement: passo 8, imagem 2 %32
    • Use a spudger to lift the black clip on the small purple ribbon cable connector to the left of the touchpad.
    • Pull the ribbon cable out from the connector.
  9. Acer Chromebook C740 Trackpad Replacement: passo 9, imagem 1 %32 Acer Chromebook C740 Trackpad Replacement: passo 9, imagem 2 %32
    • Remove the five 2.5 mm screws with a Phillips #0 screwdriver.
  10. Acer Chromebook C740 Trackpad Replacement: passo 10, imagem 1 %32 Acer Chromebook C740 Trackpad Replacement: passo 10, imagem 2 %32
    • Remove the four 2.8 mm screws with a Phillips #00 screwdriver.
  11. Acer Chromebook C740 Trackpad Replacement: passo 11, imagem 1 %32 Acer Chromebook C740 Trackpad Replacement: passo 11, imagem 2 %32
    • Wiggle off the silver bracket with your fingers.
  12. Acer Chromebook C740 Trackpad Replacement: passo 12, imagem 1 %32 Acer Chromebook C740 Trackpad Replacement: passo 12, imagem 2 %32
    • Remove the black tape on the left side of the touchpad.
  13. Acer Chromebook C740 Trackpad Replacement: passo 13, imagem 1 %32 Acer Chromebook C740 Trackpad Replacement: passo 13, imagem 2 %32
    • Lift off the black plastic cover with the plastic opening tool.
Conclusão
6 outras pessoas executaram este guia.
Flor De La Rosa
Membro desde: 04/25/17
875 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S22-G2, Livingston Spring 2017 Membro de Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 21
Duração total: 2,551
