Introdução
The trackpad replacement for the Acer Chromebook C740 requires removing the back panel, removing the battery, unplugging a ribbon cable, and removing several screws.
O que você precisa
Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
Pull the black wire out from under the the black center clips and up from the gray outer clips with a spudger.
6 outras pessoas executaram este guia.
