Ir para o conteúdo principal
Acer Chromebook C740 Motherboard Replacement
O que você precisa
  1. Acer Chromebook C740 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 Motherboard Replacement: passo 2, imagem 1 %32 Acer Chromebook C740 Motherboard Replacement: passo 2, imagem 2 %32
    • Place the chromebook bottom side up on a flat surface.
    • Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
  3. Acer Chromebook C740 Motherboard Replacement: passo 3, imagem 1 %32 Acer Chromebook C740 Motherboard Replacement: passo 3, imagem 2 %32 Acer Chromebook C740 Motherboard Replacement: passo 3, imagem 3 %32
    • Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
    • Applying pressure may be necessary. A click indicates the panel is ready to come off.
  4. Acer Chromebook C740 Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 Acer Chromebook C740 Motherboard Replacement, Motherboard: passo 4, imagem 2 %32 Acer Chromebook C740 Motherboard Replacement, Motherboard: passo 4, imagem 3 %32
    • Flip up the clip holding down the white cable using the spudger.
    • Pull the cable outwards towards the battery.
  5. Acer Chromebook C740 Motherboard Replacement: passo 5, imagem 1 %32 Acer Chromebook C740 Motherboard Replacement: passo 5, imagem 2 %32 Acer Chromebook C740 Motherboard Replacement: passo 5, imagem 3 %32
    • Flip up the clip holding down the white cable using the flat end of the spudger.
  6. Acer Chromebook C740 Motherboard Replacement: passo 6, imagem 1 %32 Acer Chromebook C740 Motherboard Replacement: passo 6, imagem 2 %32 Acer Chromebook C740 Motherboard Replacement: passo 6, imagem 3 %32
    • Flip up the white clip holding down the connector labelled "MB" using the flat end of the spudger.
    • Remove the connector by pulling out towards the battery.
  7. Acer Chromebook C740 Motherboard Replacement: passo 7, imagem 1 %32 Acer Chromebook C740 Motherboard Replacement: passo 7, imagem 2 %32 Acer Chromebook C740 Motherboard Replacement: passo 7, imagem 3 %32
    • Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
    • The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience.
  8. Acer Chromebook C740 Motherboard Replacement: passo 8, imagem 1 %32 Acer Chromebook C740 Motherboard Replacement: passo 8, imagem 2 %32 Acer Chromebook C740 Motherboard Replacement: passo 8, imagem 3 %32
    • Unplug the black connector attached to the motherboard at the top right of the battery by using a spudger to push the two L-shaped indentations towards the battery.
  9. Acer Chromebook C740 Motherboard Replacement: passo 9, imagem 1 %32 Acer Chromebook C740 Motherboard Replacement: passo 9, imagem 2 %32 Acer Chromebook C740 Motherboard Replacement: passo 9, imagem 3 %32
    • Peel back the tape covering the white connector at the top-right of the motherboard.
    • Remove the connector from its fitting by pulling outwards.
  10. Acer Chromebook C740 Motherboard Replacement: passo 10, imagem 1 %32 Acer Chromebook C740 Motherboard Replacement: passo 10, imagem 2 %32 Acer Chromebook C740 Motherboard Replacement: passo 10, imagem 3 %32
    • Unplug the white connector attached to the right of the fan with the spudger by applying force towards the battery on the two L-shaped indentations.
  11. Acer Chromebook C740 Motherboard Replacement: passo 11, imagem 1 %32 Acer Chromebook C740 Motherboard Replacement: passo 11, imagem 2 %32 Acer Chromebook C740 Motherboard Replacement: passo 11, imagem 3 %32
    • Disconnect the two white and black wires by holding close to the metal snap-on caps and pulling upwards.
  12. Acer Chromebook C740 Motherboard Replacement: passo 12, imagem 1 %32 Acer Chromebook C740 Motherboard Replacement: passo 12, imagem 2 %32
    • Remove the four 3.7 mm screws with a Phillips #0 screwdriver.
  13. Acer Chromebook C740 Motherboard Replacement: passo 13, imagem 1 %32 Acer Chromebook C740 Motherboard Replacement: passo 13, imagem 2 %32 Acer Chromebook C740 Motherboard Replacement: passo 13, imagem 3 %32
    • Loosen the two black screws with a Phillips #0 screwdriver.
    • These screws cannot be removed. However, simply loosening them allows the heatsink fan to lift away from the motherboard.
    • Lift the heatsink fan and rotate it away from the mother board to set down outside the laptop.
  14. Acer Chromebook C740 Motherboard Replacement: passo 14, imagem 1 %32 Acer Chromebook C740 Motherboard Replacement: passo 14, imagem 2 %32 Acer Chromebook C740 Motherboard Replacement: passo 14, imagem 3 %32
    • Remove the 3.63 mm screw in the top right near the hinge with a Phillips #0 screwdriver.
    • Remove the 3.75 mm screw near the top right corner of the battery with a Phillips #0 screwdriver.
  15. Acer Chromebook C740 Motherboard Replacement: passo 15, imagem 1 %32 Acer Chromebook C740 Motherboard Replacement: passo 15, imagem 2 %32
    • Remove the 3.75 mm screw with a Phillips #0 screwdriver.
  16. Acer Chromebook C740 Motherboard Replacement: passo 16, imagem 1 %32
    • Unplug the solid state drive.
  17. Acer Chromebook C740 Motherboard Replacement: passo 17, imagem 1 %32
    • Carefully lift the motherboard away from the laptop with two hands.
Conclusão
4 outras pessoas executaram este guia.
William Yu
Membro desde: 04/26/17
283 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S22-G2, Livingston Spring 2017 Membro de Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 43
Duração total: 3,159
