Ir para o conteúdo principal
Acer Chromebook C740 LCD Screen Replacement
O que você precisa
  1. Acer Chromebook C740 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 LCD Screen Replacement: passo 2, imagem 1 %32 Acer Chromebook C740 LCD Screen Replacement: passo 2, imagem 2 %32
    • With the Chromebook open and face up, pry the black screen frame with your fingers.
    • Move slowly around the display to evenly remove it.
    • Clicking sounds indicate the panel is seperating from the overall display.
  3. Acer Chromebook C740 LCD Screen Replacement: passo 3, imagem 1 %32
    • Once the frame is separated from the display, angle the display assembly back .
    • Lift up the portions of the frame covering the front two hinges with the spudger.
  4. Acer Chromebook C740 LCD Screen Replacement: passo 4, imagem 1 %32
    • Remove the frame from the screen assembly by pulling the frame towards you.
    • Some adjustment of the display assembly may be needed so that the frame is not stuck near the hinges.
  5. Acer Chromebook C740 LCD Screen Replacement: passo 5, imagem 1 %32 Acer Chromebook C740 LCD Screen Replacement: passo 5, imagem 2 %32
    • Remove the six 3.35mm screws with a Phillips #0 Screwdriver.
  6. Acer Chromebook C740 LCD Screen Replacement: passo 6, imagem 1 %32 Acer Chromebook C740 LCD Screen Replacement: passo 6, imagem 2 %32 Acer Chromebook C740 LCD Screen Replacement: passo 6, imagem 3 %32
    • Place the LCD screen face down on the keyboard.
    • Remove the tape holding the black connector in place.
    • Unplug the connector with your hands.
Conclusão
7 outras pessoas executaram este guia.
Grace Bassett
Membro desde: 04/26/17
217 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S22-G2, Livingston Spring 2017 Membro de Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
Membros da 4
Autoria de 12 guias
Um comentário
You actually don’t need to unscrew the middle screws, and you don’t need to buy a new bezel.
Keith Hudson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 3,345
