Pular para o conteúdo principal
Introdução
Prerequisite Only
  1. Power down the Chromebook and disconnect the power adapter.
    • Power down the Chromebook and disconnect the power adapter.
  2. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  3. Place the chromebook bottom side up on a flat surface. Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
    • Place the chromebook bottom side up on a flat surface.
    • Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
  4. Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel. Applying pressure may be necessary. A click indicates the panel is ready to come off. Applying pressure may be necessary. A click indicates the panel is ready to come off.
    • Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
    • Applying pressure may be necessary. A click indicates the panel is ready to come off.
Conclusão
Flor De La Rosa
Membro desde: 25-04-2017
709 reputação
4 Guias de autoria
Equipe
Cal Poly, Team S22-G2, Livingston Spring 2017 Membro de Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
4 Membros
6 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 41
