Ir para o conteúdo principal
Acer Chromebook C720-2848 Trackpad Replacement
O que você precisa
  1. Acer Chromebook C720-2848 Trackpad Replacement, Back Cover: passo 1, imagem 1 %32 Acer Chromebook C720-2848 Trackpad Replacement, Back Cover: passo 1, imagem 2 %32
    • Use a Phillips head screw driver to remove the 13 screws in these locations.
  2. Acer Chromebook C720-2848 Trackpad Replacement: passo 2, imagem 1 %32 Acer Chromebook C720-2848 Trackpad Replacement: passo 2, imagem 2 %32 Acer Chromebook C720-2848 Trackpad Replacement: passo 2, imagem 3 %32
    • Use a plastic spudger to pry up the bottom cover and remove it.
    • Be sure to pry along other edges if necessary to avoid damaging the back cover.
  3. Acer Chromebook C720-2848 Trackpad Replacement, Battery: passo 3, imagem 1 %32 Acer Chromebook C720-2848 Trackpad Replacement, Battery: passo 3, imagem 2 %32 Acer Chromebook C720-2848 Trackpad Replacement, Battery: passo 3, imagem 3 %32
    • Unscrew the 2 battery screws.
    • Make sure you keep these screws separate from the back cover screws; they are different!
  4. Acer Chromebook C720-2848 Trackpad Replacement: passo 4, imagem 1 %32 Acer Chromebook C720-2848 Trackpad Replacement: passo 4, imagem 2 %32
    • Use two fingers to unplug the battery-to-motherboard connection.
  5. Acer Chromebook C720-2848 Trackpad Replacement: passo 5, imagem 1 %32
    • Take out battery by lifting it up in the manner pictured.
  6. Acer Chromebook C720-2848 Trackpad Replacement, Trackpad: passo 6, imagem 1 %32 Acer Chromebook C720-2848 Trackpad Replacement, Trackpad: passo 6, imagem 2 %32
    • Remove 9 trackpad screws. They will be of two different varieties.
    • Make sure to keep these screw separate from those in the previous steps.
    • On the back of the trackpad, there is a plastic film that will cover some of the screws. Simply pull it back (do not pull if off) to remove the screws.
  7. Acer Chromebook C720-2848 Trackpad Replacement: passo 7, imagem 1 %32 Acer Chromebook C720-2848 Trackpad Replacement: passo 7, imagem 2 %32
    • Remove the trackpad ribbon cable.
    • To do this, lift the small black component; it is hinged to the white component.
    • Then simply pull the ribbon cable out of the connector.
  8. Acer Chromebook C720-2848 Trackpad Replacement: passo 8, imagem 1 %32 Acer Chromebook C720-2848 Trackpad Replacement: passo 8, imagem 2 %32 Acer Chromebook C720-2848 Trackpad Replacement: passo 8, imagem 3 %32
    • Remove the small metal frame by simply lifting it out.
    • Carefully peel up the tape holding the trackpad in place.
    • Remove the trackpad from the computer frame.
    • Make sure to watch for any wires or other components and ensure that they are out of the way when removing the trackpad.
Conclusão
Richard Schmidt
Membro desde: 03/19/18
328 Reputação
Autoria de 2 guias
Equipe
Baylor, Team S3-G1, Williams Spring 2018 Membro de Baylor, Team S3-G1, Williams Spring 2018
BU-WILLIAMS-S18S3G1
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 9
Duração total: 564
