Introdução
This guide instructs the reader how to disassemble, extract, replace, and reassemble the LCD monitor for an Acer Chomebook C720-2848.
O que você precisa
Insert a metal spudger around the inner side of the screens plastic perimeter.
Move along the perimeter while leveraging to pop the faceplate out like so.
4 outras pessoas executaram este guia.
Um comentário
In step 2, "the faceplate's bottom hinges" are plastic hinge covers that are (or, at least, were) part of the bezel. You may be able to take the bezel off while they're still attached, or you may have to break the flexing points so that they come off separately. Either way, it doesn't seem to cause a problem.
Thanks, Cory.
Lance ==)--------------
