Ir para o conteúdo principal
Acer Chromebook C720-2848 Screen Replacement
O que você precisa
  1. Acer Chromebook C720-2848  Screen Replacement, Screen: passo 1, imagem 1 %32 Acer Chromebook C720-2848  Screen Replacement, Screen: passo 1, imagem 2 %32
    • Insert a metal spudger around the inner side of the screens plastic perimeter.
    • Move along the perimeter while leveraging to pop the faceplate out like so.
  2. Acer Chromebook C720-2848  Screen Replacement: passo 2, imagem 1 %32 Acer Chromebook C720-2848  Screen Replacement: passo 2, imagem 2 %32
    • Remove the faceplate's bottom hinges that connect to the body of the device with the metal spudger. This will free the plastic perimeter, which may now be removed.
  3. Acer Chromebook C720-2848  Screen Replacement: passo 3, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the 6 screws in these circled locations.
  4. Acer Chromebook C720-2848  Screen Replacement: passo 4, imagem 1 %32
    • Reposition so the screen will lay flat on the keyboard of the laptop.
  5. Acer Chromebook C720-2848  Screen Replacement: passo 5, imagem 1 %32 Acer Chromebook C720-2848  Screen Replacement: passo 5, imagem 2 %32
    • Locate the bar code adhesion strip at the base of the screen, and then peel it back carefully. Once peeled back the plug-in will come free.
Conclusão
4 outras pessoas executaram este guia.
Cory Provost
Membro desde: 09/27/17
212 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S9-G3, Remmell Fall 2017 Membro de USF Tampa, Team S9-G3, Remmell Fall 2017
USFT-REMMELL-F17S9G3
Membros da 4
Autoria de 9 guias
Um comentário
In step 2, "the faceplate's bottom hinges" are plastic hinge covers that are (or, at least, were) part of the bezel. You may be able to take the bezel off while they're still attached, or you may have to break the flexing points so that they come off separately. Either way, it doesn't seem to cause a problem.
Thanks, Cory.
Lance ==)--------------
Lance - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 1,744
