Ir para o conteúdo principal
Acer Chromebook C720-2848 Motherboard Replacement
O que você precisa
  1. Acer Chromebook C720-2848  Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Acer Chromebook C720-2848  Motherboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Use a Phillips head screw driver to remove the 13 screws in these locations.
  2. Acer Chromebook C720-2848  Motherboard Replacement: passo 2, imagem 1 %32 Acer Chromebook C720-2848  Motherboard Replacement: passo 2, imagem 2 %32 Acer Chromebook C720-2848  Motherboard Replacement: passo 2, imagem 3 %32
    • Use a plastic spudger to pry up the bottom cover and remove it.
    • Be sure to pry along other edges if necessary to avoid damaging the back cover.
  3. Acer Chromebook C720-2848  Motherboard Replacement, Battery: passo 3, imagem 1 %32 Acer Chromebook C720-2848  Motherboard Replacement, Battery: passo 3, imagem 2 %32 Acer Chromebook C720-2848  Motherboard Replacement, Battery: passo 3, imagem 3 %32
    • Unscrew the 2 battery screws.
    • Make sure you keep these screws separate from the back cover screws; they are different!
  4. Acer Chromebook C720-2848  Motherboard Replacement: passo 4, imagem 1 %32 Acer Chromebook C720-2848  Motherboard Replacement: passo 4, imagem 2 %32
    • Use two fingers to unplug the battery-to-motherboard connection.
  5. Acer Chromebook C720-2848  Motherboard Replacement: passo 5, imagem 1 %32
    • Take out battery by lifting it up in the manner pictured.
  6. Acer Chromebook C720-2848  Motherboard Replacement, SSD: passo 6, imagem 1 %32 Acer Chromebook C720-2848  Motherboard Replacement, SSD: passo 6, imagem 2 %32
    • Unscrew screw holding SSD card in place.
    • Slide out the SSD card towards you to remove it.
    • The SSD card is the blue chip on the right connected to the motherboard.
    • Be sure to store this screw apart from the others as it is a different length.
  7. Acer Chromebook C720-2848  Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 Acer Chromebook C720-2848  Motherboard Replacement, Motherboard: passo 7, imagem 2 %32 Acer Chromebook C720-2848  Motherboard Replacement, Motherboard: passo 7, imagem 3 %32
    • Remove the three ribbon cables connected to the bottom of the motherboard.
    • Use the plastic spudger to lift the white hinges from on top of the ribbon cables.
    • Then gently pull the cables out.
  8. Acer Chromebook C720-2848  Motherboard Replacement: passo 8, imagem 1 %32 Acer Chromebook C720-2848  Motherboard Replacement: passo 8, imagem 2 %32 Acer Chromebook C720-2848  Motherboard Replacement: passo 8, imagem 3 %32
    • Remove 4 connectors from the right side of the motherboard.
    • All of these connectors release by simply pulling back.
    • To disconnect the connector shown in the third picture, you will need to peel back some tape first.
  9. Acer Chromebook C720-2848  Motherboard Replacement: passo 9, imagem 1 %32 Acer Chromebook C720-2848  Motherboard Replacement: passo 9, imagem 2 %32 Acer Chromebook C720-2848  Motherboard Replacement: passo 9, imagem 3 %32
    • On the left side of the motherboard, remove one more connector and two cables.
    • To remove the cables, lift them up with a plastic spudger.
    • Take note of which cable connects where.
  10. Acer Chromebook C720-2848  Motherboard Replacement: passo 10, imagem 1 %32 Acer Chromebook C720-2848  Motherboard Replacement: passo 10, imagem 2 %32 Acer Chromebook C720-2848  Motherboard Replacement: passo 10, imagem 3 %32
    • Remove the 2 fan screws and the 4 heat sink screws.
    • The screws don't necessarily need to be removed from the component, but rather just loosened enough to remove the component from the motherboard.
    • Now remove the fan/heat sink component.
    • Once again, make sure to keep these screws separate from all others.
  11. Acer Chromebook C720-2848  Motherboard Replacement: passo 11, imagem 1 %32 Acer Chromebook C720-2848  Motherboard Replacement: passo 11, imagem 2 %32
    • Remove the 2 motherboard screws.
    • Now you can remove the motherboard.
    • Be careful not to damage any of the loose connectors and cables you disconnected in the previous steps.
Conclusão
Uma outra pessoa concluiu este guia.
Robert Escobio
Membro desde: 09/27/17
597 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S9-G3, Remmell Fall 2017 Membro de USF Tampa, Team S9-G3, Remmell Fall 2017
USFT-REMMELL-F17S9G3
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 405
