Ir para o conteúdo principal
Acer Chromebook C720-2844 Battery Replacement
O que você precisa
  1. Acer Chromebook C720-2844 Battery Replacement, Battery: passo 1, imagem 1 %32 Acer Chromebook C720-2844 Battery Replacement, Battery: passo 1, imagem 2 %32 Acer Chromebook C720-2844 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Flip to the back cover of the laptop.
    • Remove the 1 cm Phillips #00 screws on the back cover.
    • Use pry tools to remove the back cover.
  2. Acer Chromebook C720-2844 Battery Replacement: passo 2, imagem 1 %32
    • Take out your Phillips #00 screwdriver.
    • Remove the 1 cm screws of the battery. There are two of screws, one is on the left of the battery and the other is on the right. (circled in red).
  3. Acer Chromebook C720-2844 Battery Replacement: passo 3, imagem 1 %32 Acer Chromebook C720-2844 Battery Replacement: passo 3, imagem 2 %32
    • Unplug the battery from the motherboard by pulling the bundled cable connector free.
    • Lift the top part of battery.
    • Slide the battery forward to remove it completely from the motherboard.
Conclusão
Fabian Sanchez
Membro desde: 02/10/22
247 Reputação
Autoria de 1 guia
Equipe
Gateway, Team 1-2, Pee Spring 2022 Membro de Gateway, Team 1-2, Pee Spring 2022
GCC-PEE-S22S1G2
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 196
