Ir para o conteúdo principal
Introdução
Use this guide to replace the trackpad on your Acer Chromebook C720-2827. This guide may also be useful for cleaning or readjusting a trackpad that is semi-functional. It will require opening the device and removal of the battery. A plastic cover sits atop the trackpad joined by adhesive, so some light adhesive may be desired for reassembly.
Peças
Nenhum componente especificado.
  1. Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver. Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Pry the back panel open with the plastic opening tool. Pry the back panel open with the plastic opening tool.
    • Pry the back panel open with the plastic opening tool.
  3. Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Carefully pull out the battery wire connected to the battery port. Carefully pull out the battery wire connected to the battery port.
    • Carefully pull out the battery wire connected to the battery port.
  5. Slowly lift the battery to remove it from the Chromebook.
    • Slowly lift the battery to remove it from the Chromebook.
  6. Using a spudger, pry up  the locking bar of the ZIF connector on the trackpad and remove the ribbon cable. Using a spudger, pry up  the locking bar of the ZIF connector on the trackpad and remove the ribbon cable. Using a spudger, pry up  the locking bar of the ZIF connector on the trackpad and remove the ribbon cable.
    • Using a spudger, pry up the locking bar of the ZIF connector on the trackpad and remove the ribbon cable.
  7. Peel off the clear plastic covering the screws. Remove the five grey 2.5 mm screws securing the trackpad with a Phillips #1 screwdriver. Remove another four silver 2.9mm Phillips #1 screws from the silver bracket atop the trackpad with your driver.
    • Peel off the clear plastic covering the screws.
    • Remove the five grey 2.5 mm screws securing the trackpad with a Phillips #1 screwdriver.
    • Remove another four silver 2.9mm Phillips #1 screws from the silver bracket atop the trackpad with your driver.
  8. Lift up the silver bracket. Remove the trackpad by lifting it up from the case.
    • Lift up the silver bracket.
    • Remove the trackpad by lifting it up from the case.
Conclusão
Uma outra pessoa concluiu este guia.
Austin Blakely
Membro desde: 11/03/2019
8.690 Reputação
46 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
137 Membros
16.711 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 110
