Ir para o conteúdo principal
Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement
O que você precisa
  1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Back Panel Assembly: passo 1, imagem 1 %32 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Back Panel Assembly: passo 1, imagem 2 %32
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 2, imagem 1 %32 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 2, imagem 2 %32
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Battery: passo 3, imagem 1 %32
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 4, imagem 1 %32 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 4, imagem 2 %32
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 5, imagem 1 %32
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Speakers: passo 6, imagem 1 %32 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Speakers: passo 6, imagem 2 %32
    • Unplug the speaker wire from the motherboard.
  7. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 7, imagem 1 %32 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 7, imagem 2 %32
    • Carefully pull out the speakers from each side of the Chromebook.
  8. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: passo 8, imagem 1 %32 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: passo 8, imagem 2 %32 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: passo 8, imagem 3 %32
    • Remove the three 6.0mm screws using the Phillips #1 screwdriver.
    • Remove the two 3.0mm screws using the Phillips #1 screwdriver.
  9. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 9, imagem 1 %32 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 9, imagem 2 %32
    • Position the spudger under the switch that connects the ribbon cable to the motherboard.
    • Flick the spudger up to flip the switch up.
  10. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 10, imagem 1 %32 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 10, imagem 2 %32
    • Pull the blue tab on the ribbon cable to remove it.
  11. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 11, imagem 1 %32 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 11, imagem 2 %32
    • Grab the edges of each piece of circuitry that is included with the SD Card Reader and USB Port.
    • Pull each piece of circuitry out of the Chromebook and remove it from the device.
  12. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 12, imagem 1 %32 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 12, imagem 2 %32
    • Position the spudger under the switch.
  13. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 13, imagem 1 %32 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: passo 13, imagem 2 %32
    • Pull on the blue tab of the ribbon cable to remove the ribbon cable.
    • Repeat the previous step and this step with the other ribbon cable that is attached to the SD Card Reader/USB Port.
Conclusão
Uma outra pessoa concluiu este guia.
Jason Bechtold
Membro desde: 10/19/17
611 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 310
