Ir para o conteúdo principal
Acer Chromebook C720-2827 Motherboard Replacement
O que você precisa
  1. Acer Chromebook C720-2827 Motherboard Replacement, Back Panel Assembly: passo 1, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement, Back Panel Assembly: passo 1, imagem 2 %32
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 Motherboard Replacement: passo 2, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 2, imagem 2 %32
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 Motherboard Replacement, Battery: passo 3, imagem 1 %32
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 Motherboard Replacement: passo 4, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 4, imagem 2 %32
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 Motherboard Replacement: passo 5, imagem 1 %32
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 Motherboard Replacement, Solid State Drive: passo 6, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement, Solid State Drive: passo 6, imagem 2 %32
    • Remove the single 3.0mm screw securing the solid state drive using a Phillips #1 screwdriver.
  7. Acer Chromebook C720-2827 Motherboard Replacement: passo 7, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 7, imagem 2 %32
    • Carefully pull out the solid state drive using two fingers.
  8. Acer Chromebook C720-2827 Motherboard Replacement, Speakers: passo 8, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement, Speakers: passo 8, imagem 2 %32
    • Unplug the speaker wire from the motherboard.
  9. Acer Chromebook C720-2827 Motherboard Replacement: passo 9, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 9, imagem 2 %32
    • Carefully pull out the speakers from each side of the Chromebook.
  10. Acer Chromebook C720-2827 Motherboard Replacement, USB Port/SD Card Reader: passo 10, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement, USB Port/SD Card Reader: passo 10, imagem 2 %32 Acer Chromebook C720-2827 Motherboard Replacement, USB Port/SD Card Reader: passo 10, imagem 3 %32
    • Remove the three 6.0mm screws using the Phillips #1 screwdriver.
    • Remove the two 3.0mm screws using the Phillips #1 screwdriver.
  11. Acer Chromebook C720-2827 Motherboard Replacement: passo 11, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 11, imagem 2 %32
    • Position the spudger under the switch that connects the ribbon cable to the motherboard.
    • Flick the spudger up to flip the switch up.
  12. Acer Chromebook C720-2827 Motherboard Replacement: passo 12, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 12, imagem 2 %32
    • Pull the blue tab on the ribbon cable to remove it.
  13. Acer Chromebook C720-2827 Motherboard Replacement: passo 13, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 13, imagem 2 %32
    • Grab the edges of each piece of circuitry that is included with the SD Card Reader and USB Port.
    • Pull each piece of circuitry out of the Chromebook and remove it from the device.
  14. Acer Chromebook C720-2827 Motherboard Replacement: passo 14, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 14, imagem 2 %32
    • Position the spudger under the switch.
  15. Acer Chromebook C720-2827 Motherboard Replacement: passo 15, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 15, imagem 2 %32
    • Pull on the blue tab of the ribbon cable to remove the ribbon cable.
    • Repeat the previous step and this step with the other ribbon cable that is attached to the SD Card Reader/USB Port.
  16. Acer Chromebook C720-2827 Motherboard Replacement, Motherboard: passo 16, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement, Motherboard: passo 16, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the four 3.0mm screws.
    • Loosen the six 3.0mm CPU screws using the Phillips #1 screwdriver.
    • The six 3.0mm CPU screws do not come out of the motherboard.
  17. Acer Chromebook C720-2827 Motherboard Replacement: passo 17, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 17, imagem 2 %32
    • Grab the wire for the two pin connector.
    • Pull the wire to disconnect it from the motherboard.
  18. Acer Chromebook C720-2827 Motherboard Replacement: passo 18, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 18, imagem 2 %32
    • Place the back of the spudger under the black wire that connects the wireless card to the motherboard.
    • Flick the spudger up to disconnect the cable from the motherboard.
  19. Acer Chromebook C720-2827 Motherboard Replacement: passo 19, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 19, imagem 2 %32
    • Place the back of the spudger under the white coaxial antenna wire that connects the wireless card to the motherboard.
  20. Acer Chromebook C720-2827 Motherboard Replacement: passo 20, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 20, imagem 2 %32
    • Take both wires and unravel them from the CPU fan.
  21. Acer Chromebook C720-2827 Motherboard Replacement: passo 21, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 21, imagem 2 %32
    • Firmly grasp the red, yellow, and white cords with two fingers.
    • Pull the cords to unplug it.
  22. Acer Chromebook C720-2827 Motherboard Replacement: passo 22, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 22, imagem 2 %32
    • Position the spudger under the switch of the big ribbon cable.
  23. Acer Chromebook C720-2827 Motherboard Replacement: passo 23, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 23, imagem 2 %32
    • Grab the blue tab of the ribbon cable.
    • Pull on the blue tab to disconnect the ribbon cable.
  24. Acer Chromebook C720-2827 Motherboard Replacement: passo 24, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 24, imagem 2 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 24, imagem 3 %32
    • Grab the red and black cable near the display cables, this is the cable to the other two pin connector.
    • Pull on the wire to disconnect it from the motherboard.
    • Flip the wire and the connector up to move it out of the way.
  25. Acer Chromebook C720-2827 Motherboard Replacement: passo 25, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 25, imagem 2 %32
    • Position the spudger under the switch for the smaller ribbon cable.
    • Flick the spudger up to flip the smaller switch up.
  26. Acer Chromebook C720-2827 Motherboard Replacement: passo 26, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 26, imagem 2 %32
    • Grab the blue tab on the ribbon cable.
    • Pull on the tab to disconnect the ribbon cable from the motherboard.
  27. Acer Chromebook C720-2827 Motherboard Replacement: passo 27, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 27, imagem 2 %32
    • Position the back of the spudger at the edge of the tape that holds the display cable in.
    • Peel the tape back so it is out of the way.
  28. Acer Chromebook C720-2827 Motherboard Replacement: passo 28, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 28, imagem 2 %32
    • Position the back of the spudger on the display cable.
    • Push the display cable out using the back of the spudger.
  29. Acer Chromebook C720-2827 Motherboard Replacement: passo 29, imagem 1 %32 Acer Chromebook C720-2827 Motherboard Replacement: passo 29, imagem 2 %32
    • Lift up the CPU fan to ensure that no wires are tangled. If the black and white wires are tangles please repeat step 5.
    • Lift up the other end of the motherboard to completely remove the motherboard.
Conclusão
Jason Bechtold
Membro desde: 10/19/17
611 Reputação
Autoria de 5 guias
Equipe
Um comentário
Plz mujhy mother bother chaiya Chromebook ma ya Merry num 03487834288
Sheryer Shakeel ahmed - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 324
