Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
Pry the back panel open with the plastic opening tool.
Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
Carefully pull out the battery wire connected to the battery port.
Slowly lift the battery to remove it from the Chromebook.
Use the Phillips #1 screwdriver to remove the two 3.1mm screws from the LED PCB.
Lift the LED PCB up with your fingers and flip it over revealing the ZIF connector.
Set the LED PCB down and use your spudger to flip up the white bar of the ZIF connector.
Pull the ribbon cable out with your fingers.
