Ir para o conteúdo principal
Acer Chromebook C720-2827 LED PCB Replacement
O que você precisa
  1. Acer Chromebook C720-2827 LED PCB Replacement, Back Panel Assembly: passo 1, imagem 1 %32 Acer Chromebook C720-2827 LED PCB Replacement, Back Panel Assembly: passo 1, imagem 2 %32
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 LED PCB Replacement: passo 2, imagem 1 %32 Acer Chromebook C720-2827 LED PCB Replacement: passo 2, imagem 2 %32
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 LED PCB Replacement, Battery: passo 3, imagem 1 %32
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 LED PCB Replacement: passo 4, imagem 1 %32 Acer Chromebook C720-2827 LED PCB Replacement: passo 4, imagem 2 %32
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 LED PCB Replacement: passo 5, imagem 1 %32
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: passo 6, imagem 1 %32 Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: passo 6, imagem 2 %32 Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: passo 6, imagem 3 %32
    • Use the Phillips #1 screwdriver to remove the two 3.1mm screws from the LED PCB.
    • Lift the LED PCB up with your fingers and flip it over revealing the ZIF connector.
    • The LED PCB is still tethered to the daughterboard via a ribbon cable so be sure not to yank it out or it could cause damage to the cable or its connectors.
  7. Acer Chromebook C720-2827 LED PCB Replacement: passo 7, imagem 1 %32 Acer Chromebook C720-2827 LED PCB Replacement: passo 7, imagem 2 %32 Acer Chromebook C720-2827 LED PCB Replacement: passo 7, imagem 3 %32
    • Set the LED PCB down and use your spudger to flip up the white bar of the ZIF connector.
    • Pull the ribbon cable out with your fingers.
Conclusão
Sarah Westberg
Membro desde: 03/11/19
23.116 Reputação
Autoria de 70 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.767 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 231
