Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
Use the plastic opening tool to carefully remove the bottom.
Remove the two 3.6 mm Phillips screws holding the battery in place.
Ferramenta utilizada nesse passo:Tweezers$4.99-
Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
Remove the six 4.7 mm Phillips screws that secure the fan.
Disconnect these cables from the motherboard using the tweezers.
Pull out the fan.
Remove the 3.6 mm Phillips screw that secures the SSD in place.
Remove the two 3.7 mm Phillips screws that hold the motherboard in place.
Lift up the black tab on the ZIF connector to release the ribbon cable.
Carefully remove the ribbon cable.
Gently remove the ribbon cable
Remove the ribbon cable.
