Ir para o conteúdo principal
Acer Chromebook C720-2420 Motherboard Replacement
O que você precisa
  1. Acer Chromebook C720-2420 Motherboard Replacement, Back Cover Replacement: passo 1, imagem 1 %32 Acer Chromebook C720-2420 Motherboard Replacement, Back Cover Replacement: passo 1, imagem 2 %32
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer Chromebook C720-2420 Motherboard Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer Chromebook C720-2420 Motherboard Replacement, Battery: passo 3, imagem 1 %32 Acer Chromebook C720-2420 Motherboard Replacement, Battery: passo 3, imagem 2 %32
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer Chromebook C720-2420 Motherboard Replacement: passo 4, imagem 1 %32 Acer Chromebook C720-2420 Motherboard Replacement: passo 4, imagem 2 %32
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer Chromebook C720-2420 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the battery.
  6. Acer Chromebook C720-2420 Motherboard Replacement, cooling fan / CPU heat sink assembly: passo 6, imagem 1 %32 Acer Chromebook C720-2420 Motherboard Replacement, cooling fan / CPU heat sink assembly: passo 6, imagem 2 %32
    • Remove the six 4.7 mm Phillips screws that secure the fan.
  7. Acer Chromebook C720-2420 Motherboard Replacement: passo 7, imagem 1 %32 Acer Chromebook C720-2420 Motherboard Replacement: passo 7, imagem 2 %32 Acer Chromebook C720-2420 Motherboard Replacement: passo 7, imagem 3 %32
    • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
    • Pull out the fan.
  8. Acer Chromebook C720-2420 Motherboard Replacement, Memory: passo 8, imagem 1 %32 Acer Chromebook C720-2420 Motherboard Replacement, Memory: passo 8, imagem 2 %32
    • Remove the 3.6 mm Phillips screw that secures the SSD in place.
  9. Acer Chromebook C720-2420 Motherboard Replacement: passo 9, imagem 1 %32 Acer Chromebook C720-2420 Motherboard Replacement: passo 9, imagem 2 %32
    • Pull out the SSD.
  10. Acer Chromebook C720-2420 Motherboard Replacement, Motherboard: passo 10, imagem 1 %32
    • Disconnect the speaker cable from the motherboard.
  11. Acer Chromebook C720-2420 Motherboard Replacement: passo 11, imagem 1 %32
    • Disconnect the display cable from the motherboard.
  12. Acer Chromebook C720-2420 Motherboard Replacement: passo 12, imagem 1 %32
    • Gently pull out the wire for the 2 PIC connectors.
  13. Acer Chromebook C720-2420 Motherboard Replacement: passo 13, imagem 1 %32
    • Remove the two 3.7 mm Phillips screws that hold the motherboard in place.
  14. Acer Chromebook C720-2420 Motherboard Replacement: passo 14, imagem 1 %32
    • Lift up the black tab on the ZIF connector to release the ribbon cable.
    • Carefully remove the ribbon cable.
  15. Acer Chromebook C720-2420 Motherboard Replacement: passo 15, imagem 1 %32
    • Gently remove the ribbon cable
  16. Acer Chromebook C720-2420 Motherboard Replacement: passo 16, imagem 1 %32
    • Remove the ribbon cable.
  17. Acer Chromebook C720-2420 Motherboard Replacement: passo 17, imagem 1 %32
    • Lift up and remove the motherboard.
Conclusão
Josue Pardo
Membro desde: 02/12/18
187 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S15-G4, Boczar Spring 2018 Membro de USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 Membros
12 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 270
