Ir para o conteúdo principal
Introdução
This guide will provide you with the most practical way to remove the memory card off your C720-2420 Chromebook with a couple of steps.
  1. Place your Chromebook upside down. Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Use the plastic opening tool to carefully remove the bottom.
    • Use the plastic opening tool to carefully remove the bottom.
  3. Remove the 3.6 mm  Phillips screw that secures the SSD in place. Remove the 3.6 mm  Phillips screw that secures the SSD in place.
    • Remove the 3.6 mm Phillips screw that secures the SSD in place.
  4. Pull out the SSD. Pull out the SSD.
    • Pull out the SSD.
Conclusão
2 outras pessoas concluíram este guia.
Jessica Beckford
Membro desde: 12/02/2018
527 Reputação
4 Guias de autoria
Equipe
USF Tampa, Team S15-G4, Boczar Spring 2018 Membro de USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 Membros
12 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 187
