Ir para o conteúdo principal
Acer Chromebook C720-2103 Solid State Drive Replacement
O que você precisa
  1. Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: passo 1, imagem 1 %32 Acer Chromebook C720-2103 Solid State Drive Replacement, Battery: passo 1, imagem 2 %32
    • Shut the device off.
    • Turn the device over so the bottom is facing up.
    • Remove all thirteen 6mm screws using a Phillips #0 screwdriver.
    • Remember to keep screws separated by step and their locations in the device. This will help prevent confusion during reassembly.
    • Removing the battery is necessary to prevent electric shock during part replacement.
  2. Acer Chromebook C720-2103 Solid State Drive Replacement: passo 2, imagem 1 %32
    • Wedge a plastic opening tool between the back casing and the rest of the device.
    • Apply pressure up and down carefully, until backing pops up. Repeat this process in multiple spots if needed.
    • It is easiest to start at the back of the device, between the hinges of the screen.
    • Do not apply too much force. This will crack the plastic.
  3. Acer Chromebook C720-2103 Solid State Drive Replacement: passo 3, imagem 1 %32
    • Remove the three 6mm screws indicated by the red circles with a Phillips #0 screwdriver.
  4. Acer Chromebook C720-2103 Solid State Drive Replacement: passo 4, imagem 1 %32 Acer Chromebook C720-2103 Solid State Drive Replacement: passo 4, imagem 2 %32
    • Pull the rainbow cable connector out of the white terminal by wiggling it gently from side to side with your fingers.
    • Be careful when removing the cable. Too much force can damage the motherboard or the cable connector.
  5. Acer Chromebook C720-2103 Solid State Drive Replacement: passo 5, imagem 1 %32 Acer Chromebook C720-2103 Solid State Drive Replacement: passo 5, imagem 2 %32
    • Lift the battery straight up and out of the device with your hands. Take care not to knock the battery against another component.
  6. Acer Chromebook C720-2103 Solid State Drive Replacement, Solid State Drive: passo 6, imagem 1 %32
    • Remove one 6mm screw using a Phillips #0 screwdriver.
  7. Acer Chromebook C720-2103 Solid State Drive Replacement: passo 7, imagem 1 %32 Acer Chromebook C720-2103 Solid State Drive Replacement: passo 7, imagem 2 %32 Acer Chromebook C720-2103 Solid State Drive Replacement: passo 7, imagem 3 %32
    • Carefully remove the solid state drive from the solid state drive slot by sliding it downward away from the motherboard.
Conclusão
Matthew Holt
Membro desde: 10/17/17
633 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S66-G3, Rockett Fall 2017 Membro de UMass Dartmouth, Team S66-G3, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 270
