Ir para o conteúdo principal
Acer Chromebook C720 Solid State Drive (SSD) Replacement
O que você precisa
  1. Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): passo 1, imagem 1 %32 Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): passo 1, imagem 2 %32 Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): passo 1, imagem 3 %32
    • WARNING: Make sure your device is turned off before proceeding. If you proceed with the device on, the device may be damaged
    • Remove the thirteen 6mm screws using the Phillips #0 screwdriver.
    • Using the blue plastic case opener, unlatch the back of the case to expose the motherboard and other components.
  2. Acer Chromebook C720 Solid State Drive (SSD) Replacement: passo 2, imagem 1 %32 Acer Chromebook C720 Solid State Drive (SSD) Replacement: passo 2, imagem 2 %32 Acer Chromebook C720 Solid State Drive (SSD) Replacement: passo 2, imagem 3 %32
    • Remove the single 3mm screw holding the SSD with the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Solid State Drive (SSD) Replacement: passo 3, imagem 1 %32 Acer Chromebook C720 Solid State Drive (SSD) Replacement: passo 3, imagem 2 %32
    • Gently remove the SSD from the motherboard.
Conclusão
5 outras pessoas executaram este guia.
Benjamin Rahman
Membro desde: 04/01/19
517 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S2-G5, Harley Spring 2019 Membro de IUPUI, Team S2-G5, Harley Spring 2019
IUPUI-HARLEY-S19S2G5
Membros da 4
Autoria de 7 guias
2 comentários
When you’re looking for a replacement drive, its socket is for a B-keyed m.2 2242 (22m x 42m). I haven’t actually found any just-B-keyed on the market, so you’ll probably end up getting B+M keyed (like the stock drive).
Another guide which goes further into recovering the OS to the new drive is here: https://www.androidcentral.com/how-upgra...
Matt Beary - Responder
Mi duda es como instalo Chrome os a la ssd nueva
José De Jesús Lopez Guillen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 28
Últimos 30 dias: 137
Duração total: 5,348
