Ir para o conteúdo principal
Acer Chromebook C720 Heat Sink and Cooling Fan Replacement
O que você precisa
  1. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: passo 1, imagem 1 %32 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: passo 1, imagem 2 %32 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement, Heat Sink and Cooling Fan: passo 1, imagem 3 %32
    • Operating on your device while it is on, or plugged in may result in electrical shock. Make sure the device is not powered before continuing.
    • Remove the thirteen 6mm screws using the Phillips #0 screwdriver.
    • Gently pry the back plate off using the plastic opening tool, leveraging the groove along the device's hinge.
  2. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: passo 2, imagem 1 %32 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: passo 2, imagem 2 %32
    • Remove the four 3mm screws securing the heat sink using the Phillips #0 screwdriver.
    • Remove the two 3mm screws securing the fan using the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: passo 3, imagem 1 %32 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: passo 3, imagem 2 %32
    • Gently pry the fan module away from the motherboard. After a bit of force, it should pop out of its slot.
    • Carefully unwrap the wires from around the fan.
  4. Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: passo 4, imagem 1 %32 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: passo 4, imagem 2 %32 Acer Chromebook C720 Heat Sink and Cooling Fan Replacement: passo 4, imagem 3 %32
    • Gently disconnect the fan module from the motherboard.
Conclusão
Benjamin Rahman
Membro desde: 04/01/19
517 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S2-G5, Harley Spring 2019 Membro de IUPUI, Team S2-G5, Harley Spring 2019
IUPUI-HARLEY-S19S2G5
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 514
