Ir para o conteúdo principal
Acer Chromebook C710-2856 Motherboard Replacement
O que você precisa
  1. Acer Chromebook C710-2856 Motherboard Replacement, RAM: passo 1, imagem 1 %32 Acer Chromebook C710-2856 Motherboard Replacement, RAM: passo 1, imagem 2 %32
    • Remove the one 4.3mm Phillips #1 screw holding the back cover on.
  2. Acer Chromebook C710-2856 Motherboard Replacement: passo 2, imagem 1 %32
    • Locate the RAM and the metal clips holding the RAM in place.
  3. Acer Chromebook C710-2856 Motherboard Replacement: passo 3, imagem 1 %32 Acer Chromebook C710-2856 Motherboard Replacement: passo 3, imagem 2 %32
    • Push the two clips outwards at the same time with your fingers. The RAM will gently pop upwards.
  4. Acer Chromebook C710-2856 Motherboard Replacement: passo 4, imagem 1 %32
    • Pull the RAM out of the slot.
  5. Acer Chromebook C710-2856 Motherboard Replacement, Wi-Fi Card: passo 5, imagem 1 %32 Acer Chromebook C710-2856 Motherboard Replacement, Wi-Fi Card: passo 5, imagem 2 %32 Acer Chromebook C710-2856 Motherboard Replacement, Wi-Fi Card: passo 5, imagem 3 %32
    • Using the Phillips #1 screwdriver, remove the screw from the Wi-Fi card.
    • Carefully remove the piece of tape to allow for more room to remove the Wi-Fi card.
    • Use the blue plastic opening tool to lift and remove the Wi-Fi card from its socket.
  6. Acer Chromebook C710-2856 Motherboard Replacement: passo 6, imagem 1 %32 Acer Chromebook C710-2856 Motherboard Replacement: passo 6, imagem 2 %32 Acer Chromebook C710-2856 Motherboard Replacement: passo 6, imagem 3 %32
    • Use the blue plastic opening tool and carefully remove the connectors from the Wi-Fi card.
  7. Acer Chromebook C710-2856 Motherboard Replacement: passo 7, imagem 1 %32 Acer Chromebook C710-2856 Motherboard Replacement: passo 7, imagem 2 %32
    • Remove the Wi-Fi card.
  8. Acer Chromebook C710-2856 Motherboard Replacement, Motherboard: passo 8, imagem 1 %32
    • Unscrew the circled screws, a total of 17 (15 M 2x6 and 2 M 2x3), with a cross-head screwdriver.
  9. Acer Chromebook C710-2856 Motherboard Replacement: passo 9, imagem 1 %32 Acer Chromebook C710-2856 Motherboard Replacement: passo 9, imagem 2 %32 Acer Chromebook C710-2856 Motherboard Replacement: passo 9, imagem 3 %32
    • Using the blue plastic opening tool, work your way around the perimeter of the laptop and remove the bottom frame.
    • Be careful though, because we will not be pulling it completely apart since we will need to disconnect 2 ribbon cables first (shown in next step).
  10. Acer Chromebook C710-2856 Motherboard Replacement: passo 10, imagem 1 %32 Acer Chromebook C710-2856 Motherboard Replacement: passo 10, imagem 2 %32
    • Remove the green ribbon on the backside of the laptop by pulling on it lightly as shown.
    • Gently remove the back ribbon that is holding the two parts of the laptop together (found between the two parts that are being pulling apart).
  11. Acer Chromebook C710-2856 Motherboard Replacement: passo 11, imagem 1 %32
    • Now completely pull apart the motherboard from the underside of the laptop by pulling on the location of the arrows.
  12. Acer Chromebook C710-2856 Motherboard Replacement: passo 12, imagem 1 %32 Acer Chromebook C710-2856 Motherboard Replacement: passo 12, imagem 2 %32 Acer Chromebook C710-2856 Motherboard Replacement: passo 12, imagem 3 %32
    • Disconnect the five ribbons by pulling gently on the ribbon.
    • Unscrew the M2x3 screw.
    • Disconnect the blue connector from the motherboard.
    • Disconnect the wider white connector from the motherboard.
  13. Acer Chromebook C710-2856 Motherboard Replacement: passo 13, imagem 1 %32 Acer Chromebook C710-2856 Motherboard Replacement: passo 13, imagem 2 %32
    • Remove the motherboard from the frame.
  14. Acer Chromebook C710-2856 Motherboard Replacement: passo 14, imagem 1 %32 Acer Chromebook C710-2856 Motherboard Replacement: passo 14, imagem 2 %32 Acer Chromebook C710-2856 Motherboard Replacement: passo 14, imagem 3 %32
    • Remove the fan by unscrewing two M2x3 screws.
    • Peel the tape off the ribbon connection for easy access.
    • Use the plastic opening tool to disconnect the connector.
  15. Acer Chromebook C710-2856 Motherboard Replacement: passo 15, imagem 1 %32 Acer Chromebook C710-2856 Motherboard Replacement: passo 15, imagem 2 %32
    • Remove the fan.
  16. Acer Chromebook C710-2856 Motherboard Replacement: passo 16, imagem 1 %32
    • The motherboard is now bare of any extras and is ready to be replaced.
Conclusão
Vladimir
Membro desde: 09/27/17
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S6-G5, Remmell Fall 2017 Membro de USF Tampa, Team S6-G5, Remmell Fall 2017
USFT-REMMELL-F17S6G5
Membros da 7
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 688
