Introdução
Once your hard drive fails, it's pretty simple to replace! Just follow this guide to replace the hard drive in your device.
O que você precisa
Remove the one 4.3mm Phillips #1 screw holding the back cover on.
Remove the four 2.8mm Phillips #000 screws holding the drive onto the case.
Gently pull the drive up and away to disconnect the hard drive from its seat
Quase terminado!
Conclusão
