Ir para o conteúdo principal
Acer Chromebook C710-2833 SD Card Reader Replacement
O que você precisa
  1. Acer Chromebook C710-2833 SD Card Reader Replacement, SD Card Reader: passo 1, imagem 1 %32
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 2, imagem 1 %32 Acer Chromebook C710-2833 SD Card Reader Replacement: passo 2, imagem 2 %32
    • Remove the 6 mm Phillips #00 screw that holds the back cover on.
    • Carefully lift the cover off.
    • Place the cover and screw safely to the side for now.
  3. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 3, imagem 1 %32
    • Using the spudger or your finger, slide the battery release slider and hold in place as shown.
    • When reassembling, holding of the slider is not needed.
  4. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 4, imagem 1 %32
    • While holding the slider, pull out the old battery.
  5. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 5, imagem 1 %32 Acer Chromebook C710-2833 SD Card Reader Replacement: passo 5, imagem 2 %32 Acer Chromebook C710-2833 SD Card Reader Replacement: passo 5, imagem 3 %32
    • Remove the two 3 mm Phillips #00 screws located on the WiFi card.
    • Pop the wires off the WiFi card.
    • Tilt the WiFi card up and remove it by pulling.
  6. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 6, imagem 1 %32
    • Remove the fifteen 6 mm Phillips #00 screws holding on the plastic backing panel.
    • Remove the five 3 mm Phillips #00 screws holding on the plastic backing panel.
  7. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 7, imagem 1 %32 Acer Chromebook C710-2833 SD Card Reader Replacement: passo 7, imagem 2 %32 Acer Chromebook C710-2833 SD Card Reader Replacement: passo 7, imagem 3 %32
    • Use the opening tool to pull the tabs back for the ribbon cable of the Solid State Drive.
    • Gently pull the ribbon cable out.
    • Remove the Solid State Drive.
  8. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 8, imagem 1 %32 Acer Chromebook C710-2833 SD Card Reader Replacement: passo 8, imagem 2 %32
    • Use the opening tool to pull the tabs back for the ribbon cable located under the RAM board.
    • Gently pull the ribbon cable out from under the RAM board using the angled tweezers.
  9. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 9, imagem 1 %32 Acer Chromebook C710-2833 SD Card Reader Replacement: passo 9, imagem 2 %32
    • Use the opening tool to pry apart the seam around the outer perimeter of the back casing.
    • Pry apart the back casing from the keyboard housing.
  10. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 10, imagem 1 %32 Acer Chromebook C710-2833 SD Card Reader Replacement: passo 10, imagem 2 %32
    • Use the opening tool to pull back the tabs on the ribbon cable still connecting the keyboard and the back panel.
    • Use the angled tweezers to gently remove the ribbon cable.
  11. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 11, imagem 1 %32
    • Lift the keyboard off of the back casing.
  12. Acer Chromebook C710-2833 SD Card Reader Replacement: passo 12, imagem 1 %32
    • Use a soldering iron to de-solder the nodes shown on the SD Card Reader. There will be 11 nodes above (see the wide red rectangle), and one node on each side (see two red squares).
    • Remove and replace the SD Card Reader.
Conclusão
Chase Wilderman
Membro desde: 10/31/18
205 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G6, Harley Fall 2018 Membro de IUPUI, Team S1-G6, Harley Fall 2018
IUPUI-HARLEY-F18S1G6
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 959
