Ir para o conteúdo principal
Acer Chromebook C710-2833 RAM Module Replacement
O que você precisa
  1. Acer Chromebook C710-2833 RAM Module Replacement, RAM Module: passo 1, imagem 1 %32
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 RAM Module Replacement: passo 2, imagem 1 %32 Acer Chromebook C710-2833 RAM Module Replacement: passo 2, imagem 2 %32
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the screw and cover safely to the side for now.
  3. Acer Chromebook C710-2833 RAM Module Replacement: passo 3, imagem 1 %32 Acer Chromebook C710-2833 RAM Module Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
  4. Acer Chromebook C710-2833 RAM Module Replacement: passo 4, imagem 1 %32 Acer Chromebook C710-2833 RAM Module Replacement: passo 4, imagem 2 %32 Acer Chromebook C710-2833 RAM Module Replacement: passo 4, imagem 3 %32
    • Locate the RAM module.
    • Squeeze the two metal clips on the sides of the RAM module to pop the RAM out.
    • Carefully remove from the slot.
    • When reassembling, stick RAM into slot and push down until a clicking sound is heard.
Conclusão
Uma outra pessoa concluiu este guia.
Nicholas Latorre
Membro desde: 09/28/17
558 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G6, Nance Fall 2017 Membro de USF Tampa, Team S1-G6, Nance Fall 2017
USFT-NANCE-F17S1G6
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 803
