Ir para o conteúdo principal
Acer Chromebook C710-2847 Back Cover Replacement
O que você precisa
  1. Acer Chromebook C710-2847 Back Cover Replacement, Battery: passo 1, imagem 1 %32 Acer Chromebook C710-2847 Back Cover Replacement, Battery: passo 1, imagem 2 %32
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 Back Cover Replacement: passo 2, imagem 1 %32 Acer Chromebook C710-2847 Back Cover Replacement: passo 2, imagem 2 %32
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 Back Cover Replacement, Acer Chromebook C710-2847 Back Cover Replacement: passo 3, imagem 1 %32
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
  4. Acer Chromebook C710-2847 Back Cover Replacement: passo 4, imagem 1 %32 Acer Chromebook C710-2847 Back Cover Replacement: passo 4, imagem 2 %32
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
Conclusão
9 outras pessoas executaram este guia.
Bradley Pavy
Membro desde: 09/30/13
1.257 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 13-3, Forte Fall 2013 Membro de Cal Poly, Team 13-3, Forte Fall 2013
CPSU-FORTE-F13S13G3
Membros da 5
Autoria de 14 guias
Um comentário
Once you have the back cover off, you can insert aluminum foil into a tiny connector, which will allow you to flash the BIOS and boot any operating system, not just ChromeOS. Using this method, I completely wiped ChromeOS from my C710 and installed Ubuntu 16.04 LTS. Definitely worth it, because now I have a sub-$300 Linux netbook with a removable battery, standard keyboard with CAPS lock (most Chromebooks don't), and no ugly Windows key.
Uncle Happy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 22
Duração total: 6,308
