Ir para o conteúdo principal
Acer Chromebook 15 CB5-571-C09S Track Pad Replacement
O que você precisa
  1. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement, Back Cover: passo 1, imagem 1 %32
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 2, imagem 1 %32 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 2, imagem 2 %32
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 3, imagem 1 %32 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 3, imagem 2 %32
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 4, imagem 1 %32 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 4, imagem 2 %32
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement, Battery: passo 5, imagem 1 %32 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement, Battery: passo 5, imagem 2 %32 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement, Battery: passo 5, imagem 3 %32
    • The battery is the large black rectangle located in the bottom center of the device.
    • Unscrew the single black 5 mm PH00 Phillips head screw holding the battery in place located at the top right corner of the battery.
  6. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 6, imagem 1 %32 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 6, imagem 2 %32 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 6, imagem 3 %32
    • Disconnect the battery connector from the motherboard using two plastic opening tools.
    • The battery connector is the white "plug" that connects the battery to the motherboard with rainbow colored wires attached to it.
    • Use two of the plastic opening tools on either edge of the battery connector and carefully pull out the battery connector out from the motherboard.
  7. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 7, imagem 1 %32 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 7, imagem 2 %32
    • Once the battery has been disconnected from the motherboard it can easily be removed from the device.
    • Grab the top edge of the battery and carefully pull it up and out of the device towards you.
  8. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement, Track Pad: passo 8, imagem 1 %32 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement, Track Pad: passo 8, imagem 2 %32
    • The track pad is located in the bottom center of the device where the battery used to be.
    • Unscrew the seven 2 mm PH00 Phillips head screws.
  9. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 9, imagem 1 %32 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 9, imagem 2 %32 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 9, imagem 3 %32
    • Remove the track pad connector from the motherboard.
    • The track pad connector is the white "plug" located at the bottom right corner of the motherboard with a blue and silver ribbon attached to it.
    • Use two of the plastic opening tools to grab either side of the track pad connector and carefully pull it out from the motherboard.
  10. Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 10, imagem 1 %32 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 10, imagem 2 %32 Acer Chromebook 15 CB5-571-C09S Track Pad Replacement: passo 10, imagem 3 %32
    • Grab the track pad from its corners and carefully pull it up and out of the device.
Conclusão
Sakiynah Howard
Membro desde: 10/17/17
1.000 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 Membro de UMass Dartmouth, Team S1-G3, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G3
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 397
