Introdução
This guide will walk you through replacing the track pad in your Acer Chromebook 15 CB5-571-C09S.
O que você precisa
Place the device on a flat surface faced down so that the fan vents are at the top of the device.
Unscrew the single black 5 mm PH00 Phillips head screw holding the battery in place located at the top right corner of the battery.
Quase terminado!
Conclusão
