Ir para o conteúdo principal
Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement
O que você precisa
  1. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Back Cover: passo 1, imagem 1 %32
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: passo 2, imagem 1 %32 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: passo 2, imagem 2 %32
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: passo 3, imagem 1 %32 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: passo 3, imagem 2 %32
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: passo 4, imagem 1 %32 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: passo 4, imagem 2 %32
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: passo 5, imagem 1 %32 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: passo 5, imagem 2 %32 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement, Solid State Drive: passo 5, imagem 3 %32
    • The Solid State Drive is the blue chip locate right beneath the fan.
    • Unscrew the 3 mm PH00 Phillips head screw located on the left side of the SSD.
  6. Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: passo 6, imagem 1 %32 Acer Chromebook 15 CB5-571-C09S Solid State Drive Replacement: passo 6, imagem 2 %32
    • Grab the top and bottom edges of the SSD and carefully pull it out from the motherboard.
Conclusão
5 outras pessoas executaram este guia.
Sakiynah Howard
Membro desde: 10/17/17
1.000 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S1-G3, Simcock Fall 2017 Membro de UMass Dartmouth, Team S1-G3, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G3
Membros da 3
Autoria de 12 guias
Um comentário
Mine has a positive and neutral wire moving away from the SSD, and removing the chip entirely hasn't impeded operation whatsoever despite me doing it to force developer mode.
Helios Bajammin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 41
Duração total: 3,350
