Ir para o conteúdo principal
Acer Chromebook 15 C910-C453 Trackpad Replacement
O que você precisa
  1. Acer Chromebook 15 C910-C453 Trackpad Replacement, Battery: passo 1, imagem 1 %32 Acer Chromebook 15 C910-C453 Trackpad Replacement, Battery: passo 1, imagem 2 %32
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 2, imagem 1 %32
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 3, imagem 1 %32 Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 3, imagem 2 %32
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 4, imagem 1 %32 Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 4, imagem 2 %32
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 5, imagem 1 %32
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Trackpad Replacement, Trackpad: passo 6, imagem 1 %32 Acer Chromebook 15 C910-C453 Trackpad Replacement, Trackpad: passo 6, imagem 2 %32
    • Unscrew the seven 6mm Phillips screws located around the trackpad.
  7. Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 7, imagem 1 %32
    • Lift up the rectangular metal plate at the base.
  8. Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 8, imagem 1 %32 Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 8, imagem 2 %32
    • Flip the black bar where the white ribbon is connected to the trackpad upward to unlock it.
    • Gently pull the white ribbon away from the trackpad.
  9. Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 9, imagem 1 %32 Acer Chromebook 15 C910-C453 Trackpad Replacement: passo 9, imagem 2 %32
    • Gently lift the trackpad up and pull towards you to remove the trackpad.
Conclusão
Equipe
Cal Poly, Team S15-G1, Banghart Spring 2017 Membro de Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
Membros da 5
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 421
