Introdução
If your Chromebook is overheating, it may be a good idea to replace the fan.
O que você precisa
Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
Sixteen 5mm Phillips screws located around the border.
Two 5mm Phillips screws located in center.
Unscrew the following Phillips #1 screws:
Two black 4mm Phillips screws located on the fan.
Four copper 4mm Phillips screws located on the heat sink.
Uma outra pessoa concluiu este guia.
