Ir para o conteúdo principal
Acer Chromebook 15 C910-C453 Fan Replacement
O que você precisa
  1. Acer Chromebook 15 C910-C453 Fan Replacement, Battery: passo 1, imagem 1 %32 Acer Chromebook 15 C910-C453 Fan Replacement, Battery: passo 1, imagem 2 %32
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Fan Replacement: passo 2, imagem 1 %32
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Fan Replacement: passo 3, imagem 1 %32 Acer Chromebook 15 C910-C453 Fan Replacement: passo 3, imagem 2 %32
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Fan Replacement: passo 4, imagem 1 %32 Acer Chromebook 15 C910-C453 Fan Replacement: passo 4, imagem 2 %32
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Fan Replacement: passo 5, imagem 1 %32
    • Remove the battery.
  6. Acer Chromebook 15 C910-C453 Fan Replacement, Fan: passo 6, imagem 1 %32
    • Unscrew the following Phillips #1 screws:
    • Two black 4mm Phillips screws located on the fan.
    • Four copper 4mm Phillips screws located on the heat sink.
  7. Acer Chromebook 15 C910-C453 Fan Replacement: passo 7, imagem 1 %32
    • Disconnect the fan from the motherboard by pulling down on the wire connector with two iFixit Opening Tools.
  8. Acer Chromebook 15 C910-C453 Fan Replacement: passo 8, imagem 1 %32
    • Lift up the fan while unwrapping the black and white wires from around the fan.
    • Do not pull wires off of the motherboard.
    • Remove the fan.
Conclusão
Uma outra pessoa concluiu este guia.
Jacob Rakestraw
Membro desde: 04/17/17
419 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S15-G1, Banghart Spring 2017 Membro de Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
Membros da 5
Autoria de 11 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 498
