Ir para o conteúdo principal
Acer Chromebook 15 C910-C453 Battery Replacement
O que você precisa
  1. Acer Chromebook 15 C910-C453 Battery Replacement, Battery: passo 1, imagem 1 %32 Acer Chromebook 15 C910-C453 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn the Chromebook onto its backside and unscrew the the following Phillips #1 screws:
    • Sixteen 5mm Phillips screws located around the border.
    • Two 5mm Phillips screws located in center.
  2. Acer Chromebook 15 C910-C453 Battery Replacement: passo 2, imagem 1 %32
    • Remove the back cover by carefully prying each side with an iFixit Opening Tool.
    • Set aside back cover.
  3. Acer Chromebook 15 C910-C453 Battery Replacement: passo 3, imagem 1 %32 Acer Chromebook 15 C910-C453 Battery Replacement: passo 3, imagem 2 %32
    • Using a spudger, carefully unplug the rainbow wires connected to the top of the battery.
  4. Acer Chromebook 15 C910-C453 Battery Replacement: passo 4, imagem 1 %32 Acer Chromebook 15 C910-C453 Battery Replacement: passo 4, imagem 2 %32
    • Unscrew the 4mm Phillips #1 screw located at the top right of battery.
  5. Acer Chromebook 15 C910-C453 Battery Replacement: passo 5, imagem 1 %32
    • Remove the battery.
Conclusão
7 outras pessoas executaram este guia.
Jacob Rakestraw
Membro desde: 04/17/17
419 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S15-G1, Banghart Spring 2017 Membro de Cal Poly, Team S15-G1, Banghart Spring 2017
CPSU-BANGHART-S17S15G1
Membros da 5
Autoria de 11 guias
Um comentário
Jacob, WELL DONE. I have an Acer 15 C910-C451 that was driving me nuts. It would hold a battery charge but only up to 17% then drain fairly rapidly duing use. It didn’t make sense that a battery would have a set of bad cells but that is probably exactly what was the problem. So new battery in hand and a set of tools designed not to harm the case I followed your instructions to the letter. BINGO ! At this moment the unit is charging from a start of 87% it is now at 96% and climbing. Thanks for the detailed pics of the process.
Thomas Revell - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 28
Duração total: 10,118
