Ir para o conteúdo principal
Acer Chromebook 14 CB3-431-C7EX Speakers Replacement
O que você precisa
  1. Acer Chromebook 14 CB3-431-C7EX Speakers Replacement, Speakers: passo 1, imagem 1 %32 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement, Speakers: passo 1, imagem 2 %32 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement, Speakers: passo 1, imagem 3 %32
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws and then remove the cover.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: passo 2, imagem 1 %32 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: passo 2, imagem 2 %32 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: passo 2, imagem 3 %32
    • Use a spudger to disconnect the speaker connector from the bottom of the sound card. The connector should slide out toward the left speaker's housing.
    • Be sure to remove the connector evenly from the port.
  3. Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: passo 3, imagem 1 %32 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: passo 3, imagem 2 %32
    • Use a Phillips #0 screwdriver to unscrew the four 5.5mm screws from the battery housing.
  4. Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: passo 4, imagem 1 %32 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: passo 4, imagem 2 %32 Acer Chromebook 14 CB3-431-C7EX Speakers Replacement: passo 4, imagem 3 %32
    • Lift the left and right speakers directly upward from the laptop to remove them.
    • Unwind the wire connecting the two speakers from the slalom.
    • The connection between the wire and the speakers may be fragile.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 335
