Ir para o conteúdo principal
Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement
O que você precisa
  1. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: passo 1, imagem 1 %32 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: passo 1, imagem 2 %32 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement, Headphone Jack: passo 1, imagem 3 %32
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: passo 2, imagem 1 %32 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: passo 2, imagem 2 %32 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: passo 2, imagem 3 %32
    • Use a spudger to disconnect the speaker connector from the bottom of the sound card. The connector should slide out toward the left speaker's housing.
    • Be sure to remove the connector evenly from the port.
  3. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: passo 3, imagem 1 %32 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: passo 3, imagem 2 %32
    • Use a spudger to carefully disconnect the ribbon connector from the right side of the sound card. The connector should slide out toward the motherboard.
    • Be sure to remove the connector evenly from the port, as the ribbon connector may be fragile.
  4. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: passo 4, imagem 1 %32 Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: passo 4, imagem 2 %32
    • Use a Phillips #0 screwdriver to unscrew the two 4mm screws.
  5. Acer Chromebook 14 CB3-431-C7EX Headphone Jack Replacement: passo 5, imagem 1 %32
    • Slide the sound card towards the motherboard until the headphone jack is out of its hole on the side of the laptop.
    • Lift the sound card directly up from the laptop to remove it.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 607
