Ir para o conteúdo principal
Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement
O que você precisa
  1. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: passo 1, imagem 1 %32 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: passo 1, imagem 2 %32 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement, Display Assembly: passo 1, imagem 3 %32
    • Use a Phillips #0 screwdriver to unscrew the eight 4mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 7mm screws.
    • iFixit's magnetic project mat is great for keeping the screws organized.
    • Remove the cover of the device by prying up from one of the edges with a spudger or plastic opening tool.
    • If the back cover is hard to remove, carefully use a metal spudger to remove the back cover.
  2. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: passo 2, imagem 1 %32 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a Phillips #0 screwdriver to unscrew the four 5.5mm screws from the screen brackets.
    • Use tweezers to set aside the ground tape (tan) and the electrical tape (black). This may need to be reconnected during reassembly.
  3. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: passo 3, imagem 1 %32 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: passo 3, imagem 2 %32 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: passo 3, imagem 3 %32
    • Use tweezers to detach the webcam connectors from the motherboard.
    • Keep in mind that the black cable connects to the left pin and the white cable connects to the right pin.
    • There may be electric tape covering the connectors. Use tweezers to set aside the tape for reuse.
  4. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: passo 4, imagem 1 %32 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: passo 4, imagem 2 %32 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: passo 4, imagem 3 %32
    • Disconnect the display panel connector from the motherboard. The connector should slide out away from the motherboard.
    • Be sure to remove the connector evenly from the port.
  5. Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: passo 5, imagem 1 %32 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: passo 5, imagem 2 %32 Acer Chromebook 14 CB3-431-C7EX Display Assembly Replacement: passo 5, imagem 3 %32
    • To remove the lid from the laptop, pivot each end on the hinge and lift the rest of the laptop up and away from the lid.
    • Remove the display assembly from the laptop case.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 20
Duração total: 813
