Ir para o conteúdo principal
Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement
O que você precisa
  1. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement, Back Cover: passo 1, imagem 2 %32 Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement, Back Cover: passo 1, imagem 3 %32
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: passo 2, imagem 1 %32
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: passo 3, imagem 1 %32 Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: passo 3, imagem 2 %32
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Back Cover Replacement: passo 4, imagem 1 %32
    • Lift off the back cover.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 605
