Ir para o conteúdo principal
Acer Chromebook 13 CB5-311-T7NN Battery Replacement
O que você precisa
  1. Acer Chromebook 13 CB5-311-T7NN Battery Replacement, Battery: passo 1, imagem 1 %32
    • Flip the computer over and use a Phillips #0 screwdriver head to remove the 13 2.5 mm bottom cover screws.
  2. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: passo 2, imagem 1 %32
    • Use your spudger to carefully pry the bottom cover away from the palm rest assembly.
    • Don't pull the cover away too hard once it's apart from the assembly because the headphone jack cable is still attached to the bottom cover.
  3. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: passo 3, imagem 1 %32
    • Use the pointed side of the spudger to disconnect the headphone jack cable from the motherboard and completely remove the bottom cover.
  4. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: passo 4, imagem 1 %32
    • Use the pointed side of the spudger to disconnect the battery cable from the motherboard.
  5. Acer Chromebook 13 CB5-311-T7NN Battery Replacement: passo 5, imagem 1 %32 Acer Chromebook 13 CB5-311-T7NN Battery Replacement: passo 5, imagem 2 %32
    • Use a Phillips #0 screwdriver head to remove the two 2.5 mm #1 battery screws.
    • Use your hands to remove the battery by gently picking it up.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 1,375
