Ir para o conteúdo principal
Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement
O que você precisa
  1. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: passo 1, imagem 1 %32 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Back Cover Replacement: passo 1, imagem 2 %32
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: passo 2, imagem 1 %32
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: passo 3, imagem 1 %32 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, Battery: passo 3, imagem 2 %32
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: passo 4, imagem 1 %32 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: passo 4, imagem 2 %32
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: passo 5, imagem 1 %32
    • Remove the battery.
  6. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: passo 6, imagem 1 %32 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement, cooling fan / CPU heat sink assembly: passo 6, imagem 2 %32
    • Remove the six 4.7 mm Phillips screws that secure the fan.
  7. Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: passo 7, imagem 1 %32 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: passo 7, imagem 2 %32 Acer C720-2420 Chromebook cooling fan + CPU heat sink Replacement: passo 7, imagem 3 %32
    • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
    • Pull out the fan.
Conclusão
Jessica Beckford
Membro desde: 02/12/18
527 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S15-G4, Boczar Spring 2018 Membro de USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 177
